FourBlades
Nov 14 2021, 03:55 PM
Looking for 1/2" phenolic spacers to go under the intake manifolds for my weber carbs for my /6.
The manifolds have 36mm holes going into the intake ports.
John
pete-stevers
Nov 14 2021, 04:17 PM
I would like to know where to get these as well!
Or know of a source that makes them.
dug
Nov 15 2021, 07:34 AM
Krieger
Nov 15 2021, 08:42 AM
I bought a set from them years ago. They needed a little sanding on each side to get them to be flatter. Get your gaskets from them too. They are thicker than the stock ones. You'll need longer studs too. I can't remember, but it may be a complete kit.
mskala
Nov 15 2021, 08:58 AM
I put a gasket on both sides of the phenolic so that doubles the number of gaskets needed to buy. OP talked about these being 1/2" thick but in reality it's probably closer to 3/16".
JmuRiz
Nov 15 2021, 12:46 PM
IronHillRestorations
Nov 15 2021, 01:34 PM
I got them from Partsclassic too.
FourBlades
Nov 15 2021, 02:37 PM
Thanks for all the leads!
I will need longer studs too.
John
speed metal army
Nov 15 2021, 07:13 PM
QUOTE(JmuRiz @ Nov 15 2021, 10:46 AM)
Yep, just bought these from PartsKlassic. Good stuff
mb911
Nov 16 2021, 05:45 AM
Youroil.net great guy works out of his home and truly appreciates the business
pete-stevers
Nov 18 2021, 11:11 PM
Ordered mine from Partsclassic
JmuRiz
Nov 19 2021, 02:03 PM
QUOTE(mb911 @ Nov 16 2021, 03:45 AM)
Good info, I may check with them too...since my heads are '74 CIS heads that have been opened up. Might make for a custom setup once I get photos with calipers measuring
Jetsetsurfshop
Nov 19 2021, 05:40 PM
FourBlades
Nov 24 2021, 01:24 PM
I got a set from Larry at Youroil.net.
They were delivered today, which was super fast these days.
Great recommendation!
John
HIPPIEKILLER
Nov 24 2021, 01:32 PM
I ordered to Klassic parts, amongst other stuff such as cover gaskets and it’s taking longer than I anticipated. I have my powered coated engine parts ready to be torqued!
FourBlades
Nov 24 2021, 01:47 PM
PMO kit comes with longer studs (which I needed), 12 gaskets, and new hardware.
All for around $70 shipped.
sixnotfour
Nov 25 2021, 06:19 AM
