Geezer914
Nov 17 2021, 05:09 PM
Those of you running 195/65rx15 tires, what tire pressure works best?
Nov 17 2021, 06:54 PM
I used that size tire on my 71 and felt like 28 front, 30 rear was good.
jim_hoyland
Nov 17 2021, 06:59 PM
I like 28. Zseems to reduce some of the road noise. ?
bbrock
Nov 17 2021, 07:07 PM
I run mine at the stock 26/29 and have no complaints.
TX914
Nov 18 2021, 08:46 AM
I'm also using 28 front, 30 rear.
Jamie
Nov 18 2021, 08:59 AM
QUOTE(TX914 @ Nov 18 2021, 06:46 AM)
Ditto on the pressure I run in my 205x65x15's on original steel 5.5"rims.
Dave_Darling
Nov 18 2021, 08:19 PM
Best for what?
I ran 36-40 in mine. Great turn-in, great grip. Wonderful for autoXing on hard-compound street tires of the day.
Anything between 28 and 32 PSI should work. Higher will be harder and feel harsher over bumps. Lower will be softer, the handling will be a bit more squishy, and it'll be more comfortable.
--DD
piscean914
Dec 12 2021, 03:18 AM
29.5 front
32.5 rear
195/65 r15 michelin's
when it's really hot or on track, i lower pressure based on wear indicators on edge of tires - i also check the pressure the next day when cold, and usually have to add to get back to above #'s
hope this helps
