QUOTE(hndyhrr @ Nov 17 2021, 06:49 PM)
Does anyone sell the hose/tubing that goes from the windshield washer bottle across and into dash and then into steering assembly?
Is this something I can get local? If so any particular size, thickness etc.
Thanks
I recently replaced my washer fluid hoses from the bottle to the wiper stalk and then back out one way check valves and finally to the washer jets. I used washer fluid hose for a 2018 Toyota CH-R that I ordered from my local dealer. It was the right amount with some left over. Price was decent for almost 7 feet of hose. The OD of the hose is thicker and more robust than stock but fits perfectly on the connections. It was a little tricky getting the hose through the front firewall grommet, so I used some Silglyde to help it through the grommet. I can get the part number if you like. Be very careful removing the hose from the windshield wiper stalk as the fittings are plastic. I very carefully cut off the old hose from the washer fittings at the column.
