think it might be mentioned in there for a USA source.
Thank you
DRPHIL914
Nov 18 2021, 09:55 AM
914rubber has a kit wit tubing etc, but your local FLAPS should have some that would work as well
PDXBob
Nov 18 2021, 01:04 PM
I just replaced my rubber tubes for windshield washer. I got 4 mm (inside diameter) rubber tubing from local parts to work and doesn’t leak- so far. PDXBob
RiqueMar
Nov 19 2021, 05:32 PM
Agree with thew two-above. I originally got the 914rubber kit, but supplemented it with some material (same stuff) from a local autocrats store - all pretty straight-forward.
Mikey914
Nov 23 2021, 01:21 AM
Our kit also uses a heavier duty material. It's basically a mix of rubber and plastic. feels more like rubber, but can be thermally set. Meaning that you can heat it up and pish it onto the fittings and it will stay.
The kit is all the way from the stock at the steering column to the squinters
