windforfun
Nov 18 2021, 01:13 PM
Do I have my seats in wrong? Given the different heights of the top back screws, did I install my seats incorrectly? Thanks.
johnhora
Nov 18 2021, 03:07 PM
You have them in correct placement....the seat rear thicker top part goes to the outside...if you go to the back of the car and look over the rear trunk into the rear window you will see that there is a curve downward to each outside....the top of the seat fills this space visually...looks good
windforfun
Nov 18 2021, 05:49 PM
QUOTE(johnhora @ Nov 18 2021, 01:07 PM)
Many thanks. You've a good eye!!!
Root_Werks
Nov 18 2021, 06:02 PM
Dang, I never noticed that before. Learn something new everyday!
Jamie
Nov 18 2021, 06:27 PM
QUOTE(windforfun @ Nov 18 2021, 11:13 AM)
I believe all driver seats have a L side notch for the handle of the hand brake.
windforfun
Nov 18 2021, 06:44 PM
QUOTE(Jamie @ Nov 18 2021, 04:27 PM)
Mine doesn't, but there's a notch in the long for the handbrake.
Dave_Darling
Nov 18 2021, 08:08 PM
IIRC, the 72+ driver's seats have a divot for the handbrake. That's in addition to the notch in the long. Not sure about the seats in the early cars with the "floppy" handbrake handle.
--DD
windforfun
Nov 19 2021, 09:39 AM
QUOTE(Dave_Darling @ Nov 18 2021, 06:08 PM)
--DD
My "73 seat doesn't have a divot. FYI. Cheers.
Jamie
Nov 19 2021, 11:31 AM
QUOTE(windforfun @ Nov 19 2021, 07:39 AM)
--DD
But my '73 does, and seats are original!
PCH
Nov 19 2021, 02:30 PM
This doesn't address the seats. Sorry to hijack the tread but it looks like your engine lid has the same fit problem as mine. The lid at the front doesn't come all the way up to the rubber seal at the rear window.
I've looked at mine very closely, and I don't see any signs of repair of the hinges. Has yours had a repair? I'm beginning to wonder if some came from the factory like that after a suds filled lunch.
windforfun
Nov 19 2021, 02:57 PM
QUOTE(PCH @ Nov 19 2021, 12:30 PM)
The lid is perfectly flush with the rubber seal (all the way up & touching). The seal looks blue from the reflected light. The lid is about 1/8" lower than the fixed side panels at the seal. One of the hinge mounts had to be welded because it was slightly loose (but not broken off). Happy Friday & speaking of suds...
rgalla9146
Nov 19 2021, 05:23 PM
If you have no relief on the the left side of either seat you probably have two passenger
seats.
Early "floppy" hand brake cars had the relief too.
windforfun
Nov 19 2021, 06:08 PM
--DD
You're correct. My driver's side seat does have a divot. I put a little more light on the subject, so to speak.
