brant
Nov 19 2021, 09:58 AM
I have another crate of parts to go through from my shed cleaning job.
All of these are going to be ACTUAL shipping. Plus the price of the part
I've been packing... and getting the final total from UPS, then charging the price we agree to with the actual shipping total.
of course picking up is always a free shipping option and comes with a driveway beer if you want one.
My local UPS is only open 12-6pm on weekdays
so although I can usually ship within 24 hours... there may be a slow down over the holidays next week
1st item:
as a core
With bracket, pulley, cable, as pictured...
SOLD
brant
Nov 19 2021, 10:10 AM
2nd item:
a complete thermostat bracket, pulley, cable, etc.
Missing the actual thermostat
it tested bad...
but if someone is needing the mounting parts and wants to buy a new Thermostat from the Samba guy...
$20 plus actual shipping
SOLD
brant
Nov 19 2021, 10:15 AM
#3
thermostat parts.
I have a few extra parts: cable, and pulleys
$5 plus shipping for a pulley and special bolt
and if you want the cable, Its included free
but I only have one cable, so the first to ask for it will get it.
one of the pulleys is early- metal
the other later style
SOLD
brant
Nov 19 2021, 10:23 AM
2 stock oil pumps
I was told that one shaft was moving and may be only a core
the 2nd has no known concerns, spins and probably needs a good cleaning.
$20 + actual shipping for both of them together.
SOLD
brant
Nov 19 2021, 10:33 AM
next.
this is a CB full flow oil pump cover for a full flow conversion
new ones$40 + actual shipping
76-914
Nov 19 2021, 10:40 AM
I'll take the thermostat Brandt
Kent
brant
a removable and machined Cam Gear for a type 4
looks like it has a stock parts number, but has had the faces machined for mounting
with hardware. I'm happy to remove the cam for shipping weight.. or include it if wanted.
These are kind of hard to find at the moment
I see AA is sold out
$50 + shipping
SOLD
brant
Nov 19 2021, 10:42 AM
QUOTE(76-914 @ Nov 19 2021, 09:40 AM)
Kent
sure thing Kent.
PM me your shipping address and I will get it boxed up this evening.
might be able to get it out today even
thank you!
brant
brant
Nov 19 2021, 10:52 AM
1.7 rockers for converting to swivel feet
I don't have the swivels
and you will notice there are only 6 of them
2 short of a set
a car I bought with a "good" engine...
(it was not good)
had 2 later rockers installed with 6 early ones.
so an incomplete set.
I'm happy to include the pictured hardware for the shafts
$55 + actual shipping for all of them with the hardware
SOLD
brant
Nov 19 2021, 10:53 AM
the hardware for the above rockers... included
brant
Nov 19 2021, 11:10 AM
4 cylinder oil filter console mount.
probably not much demand out there.
but if someone needs it.
$10 + actual shipping
brant
Nov 19 2021, 11:12 AM
I believe these are bearing pins for a type 4 case
free... to someone needing them
happy to throw them into any item
or even ship them separately in a padded envelope for shipping... (should only be a couple of dollars)
brant
Nov 19 2021, 11:58 AM
Kent, all.
I received a message from a helpful member
that the "good" thermostat should retract more
I did test it with a hair dryer
its springy.. .when I push it
and when I applied heat it expands
the one I labeled "bad" does not expand
so I do not want to sell a bad part
I'm thinking I should test it again... maybe water? and then measure it cold?
sorry I just don't want to misrepresent anything...
brant
seanpaulmc
Nov 19 2021, 04:48 PM
QUOTE(brant @ Nov 19 2021, 11:15 AM)
#3
thermostat parts.
Hello -
I'll take all in #3.
I'm at 32803.
Thanks,
Sean
brant
Nov 20 2021, 11:20 AM
QUOTE(seanpaulmc @ Nov 19 2021, 03:48 PM)
#3
thermostat parts.
Hello -
I'm at 32803.
Thanks,
Sean
Hi Sean
I’m sorry
But 2/3 are already spoken for
I think 1 is so of as a core also but waiting to hear back
Brant
seanpaulmc
Nov 20 2021, 12:59 PM
QUOTE(brant @ Nov 20 2021, 12:20 PM)
#3
thermostat parts.
Hello -
I'm at 32803.
Thanks,
Sean
Hi Sean
I’m sorry
Brant
Okay.
I need a wheel if one turns up.
Thanks
Sean
Superhawk996
Nov 20 2021, 01:51 PM
Sent you a PM on oil pumps
petlan55
Nov 20 2021, 07:14 PM
I will take the sprocket and camshaft please.
brant
Nov 21 2021, 08:01 AM
PM’s replied to
stownsen914
Nov 21 2021, 08:28 AM
Brant - interested in the rockers. Sending a PM.
brant
Nov 22 2021, 10:48 AM
windage tray. This came from a 1975 1.8
I "believe" it will also fit the 2.0 motors
I'm not sure if this is still accurate..
but I remember that at the time I was building... the tray seals did not come in the gasket kit. So I'm including a set of Used... tray seals. just in case.
SOLD
brant
Nov 22 2021, 11:12 AM
Taco Plate with cover and 2 bolts.
the sender is bad... broken
but I found a new sender for sale on Pelican
Link to replacement sendernot powder coated.
but very useable
I believe the wire holder is necessary for the sending wire, and included
$75 + actual shipping
brant
Nov 22 2021, 11:15 AM
this is an extra cover(stock) I have for a taco plate
$ 7 + actual shipping if you need one.
SOLD
brant
Nov 22 2021, 11:17 AM
non stock taco plate
I just bought this a few weeks ago
and wish I had not.
someone added a temp sender to a stock taco plate (originally designed for no sender)
should work
not stock
my mistake for buying it
$10 + actual shipping if anyone wants to give it a try
brant
Nov 22 2021, 11:21 AM
a stock oil strainer... with mesh, cover, and special expensive nut
all straight and useable.
SOLD
brant
Nov 22 2021, 11:24 AM
4 cylinder dip sticks
used, original plating not fresh.
but in good condition
$20 each plus actual shipping.
brant
Nov 22 2021, 11:32 AM
front cooling fan mounting hub
not sure what to call this
$12 + actual shipping
brant
Nov 22 2021, 11:35 AM
rubber cooling fan plug
goes on the fan center for early cars
$2 plus actual shipping
(I'm hoping to combine some items.. making these small parts cheap)
brant
Nov 22 2021, 11:36 AM
timing cover on the fan shroud
$1 +actual shipping
SOLD
brant
Nov 22 2021, 11:39 AM
this one is hard to find.
I hope 914 rubber makes them in the future
this is the rubber cover that goes on the flywheel hole (back of the motor case)
$5 + actual shipping
SOLD
brant
Nov 22 2021, 11:40 AM
2 fuel injector holding rings
Free to someone that needs them + actual shipping
brant
Nov 22 2021, 11:57 AM
4 cylinder oil cooler.
so I took this off of a running motor
its not full of shrapnel
and the motor was not blown up
$25 + actual shipping
brant
Nov 22 2021, 11:58 AM
more cooler pictures
and the special thick washers (factory) are included.
brant
Nov 22 2021, 12:07 PM
one extra piece (out of the 3 stock pieces) from a cooler mounting bracket
if you need one.. .this is free + shipping
SOLD
brant
Nov 22 2021, 12:20 PM
Push rod tubes
and stock push rods
not plated
not perfect
I recycled the ugly ones..
a few of these have minor blemishes on the tubes
the rods are all free of wear and scuff wear marks
there are 10 stock rods
and 6 tubes
brant
Nov 22 2021, 12:23 PM
Distributor clamp complete with long nut
I am pretty sure this would fit all years of 4 cylinder
brant
Nov 22 2021, 12:25 PM
Thermostat rod spring clip
I believe there are 2 when the flappers are installed
I wish I had included these with the flappers I sold previously.
if you need one or two let me know
Free + shipping
SOLD
brant
Nov 22 2021, 12:27 PM
windage gasket set
these may be trash...
I don't know if they are sold new with gasket kits these days
I have an extra set of used that I kept when new was not available
free + shipping for the red rubber gaskets
I see the case bolt plastic washers are in this picture
those will go with the case bolts
brant
Nov 22 2021, 12:31 PM
4 cylinder case bolts
extras.. and with a used set of plastic anti rattle holders
autopro
Nov 22 2021, 05:23 PM
Hi Brant, I would like to get the Flywheel hole cover, Timing cover, oil strainer mesh, cover and nut from you please.
Shipping would be to 91977 San Diego, CA.
Thanks,
Pedro
brant
Nov 23 2021, 08:21 AM
QUOTE(autopro @ Nov 22 2021, 04:23 PM)
Thanks,
Pedro
PM coming your way
Brant
brant
Nov 23 2021, 09:46 AM
a few more things left in this batch.
stock coil bracket $5 + shipping
brant
Nov 23 2021, 09:49 AM
I might need to get an additional picture.
this is a member vendor, brand new stainless coil bracket
I forget who made these... I bet I bought it over 10 years ago
Its labeled for a 1973
and if you want an extra picture of it out of the bag, I'll be happy to get that.
10$ + shipping
I just added a pic of the bracket out of the bag
curved one one end, for fan housing.
looks like its plenty large and they included a piece of self adhesive foam for that reason
I pushed on it... its flexible and could likely be formed some to your needed shape.
(I believe there were 2 sized brackets for different years, so maybe this is large for that reason)
SOLD
autopro
Nov 23 2021, 09:52 AM
Do you know if that coil bracket is the one that is mounted to the fan housing? If so I will take it.
brant
Nov 23 2021, 10:03 AM
QUOTE(autopro @ Nov 23 2021, 08:52 AM)
do you mean the new one...
let me open it and verify.. if its hooked.. or flat on the end.
brant
Nov 23 2021, 10:13 AM
I do think its for the fan housing.
let me know either way...
easy to add it to the box
brant
NARP74
Nov 23 2021, 10:33 AM
Timing is everything. I have been looking for one of those fan mount coil brackets for months. Just found one and now they start appearing...
autopro
Nov 23 2021, 11:36 AM
QUOTE(brant @ Nov 23 2021, 08:13 AM)
brant
Yes I will take the new one please!
brant
Nov 23 2021, 04:09 PM
almost finished with this batch
this is a spark plug wire holder clip
well 2 of them.
$6 + shipping... for both.. all
so there are 3 of the black plastic snap in clips
2 of the metal holder.
but the one mounted has been glued in... so I'm guessing it was loose fitting
SOLD
brant
Nov 23 2021, 04:24 PM
engine lid rubber stop
this is a 2nd one
there is another one on an old add I have out there.
rubber looks good
not new
free to anyone that wants it... + shipping
and the other one... I can also send to someone for free + shipping
throw this in with another item...
brant
