Hi Ya Matt,
I have been folllowing this thread from here in Mexico.
I pulled up a couple of pics of a bare case on Tunas web site.
Tunas Web SiteLooking at the picture from Tunas sight a couple of things come to mind.
1) You simply aren't tightening the cooler down enough to seal the cooler against the block.
2) The goop you are using may be allowing the seals to slip out of their appropriate place. or simply slide out of full contact between the block and the cooler.
3) You have a little piece "O" crap caught up in the "milled out" block recess for your seals.
4) Your block is cracked somewhere in the area of the cooler bosses. Use dye in the oil and a black light or ultra violet to find possible crack. The kind of light you use is dependent upon the dye used. Works bitchin
5) Just for shits and grins... Could it be coming out of one of the hold down stud threads? Might be an internal crack from the oil boss to a threaded section of the hold down bolts go into the block. Not likely... But I am fishing here....
5) OK, I am really reaching with this one
Could it be a crack in the block caused by some person overtightening the galley plug above the cooler. I was thinking that you must of run a tap down that hole above the cooler. Now lets take this a step furhter.
The galley plug hole runs out of thread at some point.
Kinda depends if you used a standard tap or a bottoming tap. Either way the plug starts cutting it's own threads as you tighten down the plug to bottom it out. At this point the aluminum builds up around the plug threads and starts expanding the metal around it. Kinda starts acting like a wedge being pushed down a hole. Voila..!! Cracked block..
Again.. not likely.
Maybe i have too much of an imagination...
6) Aaron drilled a little hole in your block while you were at Sklines and he is just screwing with you. (Most Probable)
Thats all I have for ya Bro... this is a most interesting issue.
And heres one more pic from Tuna's site to look at in case yur wondering what it looked like before you put da beast together.
Tuna 2Thats all I have at the moment.
Chat with you later.
Twystd1
