QUOTE(Sprout @ Dec 4 2021, 05:08 PM)
On a couple of the plugs that sit deeper in the tin, I loosen the plugs, then use a piece of rubber hose tight enough to slide over the plug to finish unscrewing it and pull it out. Same with installation, just get the plug on the hose then get it started screwing in, pull the hose off and tighten with socket.
old school vw trick - nice tip.
take it easy screwing them in.
or its helicoil time.
many a vw engine in aus showed the evidence of that.
