QUOTE(dcheek @ Dec 6 2021, 12:06 PM)
I would only replace the flywheel as a last resort. Reason? The flywheel and crank are balanced at the factory before engine assembly. They only way to do this with a replacement is to split the case remove the crank and balance with the new flywheel.
I don't think the factory ever did an assembled balance on a T4, they just balanced components separately, I've swapped OE flywheels without issue. When I have balanced OE assemblies the material removal was minimal, maybe a few grams, likely they were within stock spec. Rods are 6 gram tolerance, no end for end balance spec, etc.
That said this year I'm trying out the AA 914 flywheels and have fully balanced 4 stock 2.0 assemblies and one 80mm crank and all of these flys required a fair bit of weight taken off. About double or more than if I used a OE fly.
I also balanced two new german replacement flys the year before, one was off and the other dead nuts on.
