QUOTE(bdstone914 @ Dec 5 2021, 11:54 PM)
QUOTE(jkb081 @ Dec 5 2021, 09:36 PM)
thank you! I will check it out.
@jkb081 I have a pulley. Do you have the shoulder bolt that hold it to the case?
Good morning. I need it all. Mounting bracket, blot, cable, pulley, replacement bushings for flapper rod, and whatever ever else goes with the system to make it operate properly. Thanks! Flappers are on engine, however, I cannot get them to move. I need to pull the engine and remove the tins to see what is underneath them that is preventing them from moving. I suspect packed with leaves for starters. When I purchased the car, the engine bay was full is leaves. Could hardly see the engine. Lol!!
