After months of chasing a rich condition on my '73 1.7 I decided to once again try pressurizing the system and applying soapy water. Glad I did because I found two more leaking hoses and a leaking Cold Start Valve gasket. But the worst culprit turned out to be a leak around the throttle shaft.
There are a number of threads about options for adding bushings and or seals, but am I right in thinking this would mainly impact idle mixture? If so, I'm wondering if other system adjustments, e.g. ECU knob and/or MPS could overcome the effects of this leak - at least until I find a machine shop to fix the TB.
Thanks in advance for any suggestions.
Ron
