mmascari
Dec 9 2021, 11:53 AM
Hello, looking for assistance installing a VDO fuel gauge. I am hoping someone has installed one and knows what wires connect to what terminals. Attached photo. There are two terminals and I assume these connect to the fuel sender. There is also a red/white/black set of wires. Any assistance would be great.
mmascari
Dec 9 2021, 12:07 PM
I also have this diagram that shows stock wiring to stock fuel gauge is
Ground(Brown)
Green
2(Red/white stripe)
Luke M
Dec 9 2021, 12:41 PM
S = sensor
- = ground
+ = hot wire
The other 2 posts look to be a light ? Flip the gauge over and take a pic.
Are you sure that the gauge will work with your fuel tank sensor?
I take this is a GT style fuel gauge?
mmascari
Dec 9 2021, 12:59 PM
QUOTE(Luke M @ Dec 9 2021, 10:41 AM)
S = sensor
- = ground
+ = hot wire
I can't confirm it will work. I assume it would.
mmascari
Dec 9 2021, 03:15 PM
I found this doing a search, so maybe I need to get the correct gauge:
Posted from LarryM:
here is the info from 2004 for correct gauge
"here is the answer via VDO Support:
Use VDO Part Number 301 020 with the OEM 914 fuel sender; (spec'd for Beetle O.E. sender or VDO 221012 sender): 73 - 10 Ohms, "Fuel"
The reading will be off slightly but will not be noticeable
William M. Reichart
Technical Support
Siemens VDO Automotive Corporation
Service & Special Solutions
Phone: 1-800-265-1818 Ext. 4018
914Sixer
Dec 9 2021, 03:38 PM
914 fuel gauge is 0-90 ohms.
mmascari
Dec 9 2021, 04:36 PM
I was looking at the existing stock wiring to the fuel gauge and it shows
Ground
Green
2 red/white stripe
What is the red/white stripe wire?
I assume Green is from the sending unit
GregAmy
Dec 9 2021, 04:58 PM
Fuel gauge itself has two wires:
Red/White: keyed power
Green: to the sender
The black wire goes to the low fuel lamp
Sender has three wires:
Green: gauge
Brown: ground
Black: low fuel light inside the gauge
mmascari
Dec 9 2021, 05:02 PM
QUOTE(GregAmy @ Dec 9 2021, 02:58 PM)
Green: gauge
Brown: ground
Awesome, thanks.
So, the Red/White would go to the + terminal on the gauge, the Green to the S on the gauge and the brown to the - on the gauge?
Luke M
Dec 9 2021, 05:37 PM
QUOTE(mmascari @ Dec 9 2021, 04:02 PM)
Green: gauge
Brown: ground
Awesome, thanks.
Yup.. Like I posted earlier. What didn't believe me.. lol
mmascari
Dec 9 2021, 05:42 PM
QUOTE(Luke M @ Dec 9 2021, 03:37 PM)
Green: gauge
Brown: ground
Awesome, thanks.
Haha, thanks Luke!
GregAmy
Dec 10 2021, 09:13 AM
