QUOTE(emerygt350 @ Dec 10 2021, 12:05 PM)
Ever since I bought the car it would randomly not start. Hot/cold/whatever. Power comes on, I can see the volt gauge drop to ten when I hit the key all the way to turn the motor over, but nothing. No click, nothing. I hear a little something like relays maybe? when I turn and hold it to start. Wiggle wires, do a rain dance, slam the car door, slam the engine lid, nothing. Walk away all pissed off, come back in 1/4/6/10 minutes and sometimes it starts right up, sometimes it doesn't.
Corroded lead on the solenoid? Bad solenoid?
I spent a few weeks rebuilding my brothers 74 2.0 wire harness.
Here's what I learned along the way. Most of the wires where shot.
Once I cut into them the wires where mostly corroded and no longer copper looking.
At one point someone jumped out the relay under the pass seat with a butt connector. That connector pretty much fell apart in my hand. I ended up replacing some of that large yellow wire which runs to the starter solenoid. I installed a hot start relay in the engine bay and all new wires pretty much through out. I also found that the ignition switch was cracked too. That yellow wire runs from the switch to the starter solenoid. It's pretty easy to replace the switch. Pull your steering wheel, 2 screws holding the ignition switch housing, unplug the wires at the back of the switch, put your key in to unlock the column and out the assembly comes. remove the set screw holding the plastic switch and pull it out. They crack around where the steel insert from the lock assembly mates. You can't tell unless you go through the removal process. Test the continuity from the yellow wire at switch plug to the starter. It's a little of a pain but can be done. I can't recall if the 73 has the relay under the pass seat but if it does look real hard there as well. Also check all of your grounds. Trans & engine bay get most of the corrosion but look at all of them.
BTW where in Upstate NY are located?
