QUOTE(Luke M @ Dec 13 2021, 05:37 PM)
The fan housings changed a few times. So, yes you need the proper housing to fit the internal reg alt. that will fit your engine. As for the air channel piece that can be modified. I did just that to make it fit on my brothers engine. I had to cut the lower portion to fit over the regulator. You could buy a new piece but I had a good one on hand that just needed the mod. After the mod it fit well. Mid 75 or 76 the housings changed with the internal reg alt. Then when the 3.0 came about it slightly changed again. I have all the info someplace and will post it here once I find it.
Attached a link from classic retrofit which has a good video/info.
https://www.youtube.com/watch?v=P9dy5wSbeHkhttps://www.classicretrofit.com/products/co...175a-alternatorGreat info Luke. Love the table, it's very helpful. The classic retrofit alt looks like the wosp. Lots of info around, especially on pelican and rennsport. With the price of housings and fans, I'm likely gonna stick with what I have, at least in the beginning.
One question.... are you sure the internal reg alternator began use ~76 or was it just the housing that would work with them started being used in 76? A couple of posts on various forums implied the internal was first used around 81 or 82.
You'd think that converting older 911 engines to internal reg alts would be a common thing, but my searches for "Porsche 911 alternator convert from external to internal regulator" just don't turn up anything that's been enlightening. That's when I decided to just drop it and move on to the next problem.
Dan
