QUOTE(roblav1 @ Dec 16 2021, 10:13 PM)
Interesting setup there from Taormina Racing. 993 engines don't use an engine oil cooler, so you'll be fine with just a front cooler. You probably won't need a seperate oil thermostat either, the engine thermostat should suffice. It also looks like there's plenty of room for a simpler flexible intake hose. On my 72 911, that screw clamp into the cooler seemed funny after all the earlier 911's had the screw on fitting.
BTW, Taormina Sicily is a great place to go!
Don't want to tangent too much from the original thread, but on the topic of thermostats, the engine thermostat works on the pressure side. Since the FMC is on the scavenge side, ideally that's where the thermo needs to be located. On the pressure side, the engine thermo needs to be made where it's permanently open, flowing fully to the new filter, since it's in place of the old engine cooler, and due to restrictions through the new filter, the pressure needs to be boosted. These are the tidbits I've dug up so far researching changes in the 993/996 oil circuits.
Dan
