Did you ever have one of those days?
Ok.. here's an update on the potential starting of my /6 after 5 years......
I got the rebuilt pump from Zim's this morning and got it installed. Rolled the car outside and tried to start it. It spins over and it has oil pressure. It does not fire.
I check and there is no gas at the MFI pump, but the fuel pump is running.......
I pull the feed hose off the fuel filter console. Yep, got gas here.
So I pull the fuel filter console out. Turns out that there is a fitting on an MFI fuel filter console that acts a both a pressure regulator (holds the fuel pressure at 12 psi) and a check valve. Guess what?? I had it on the INPUT side of the fuel filter console.
Now I can open the air bleed screw on the top of the fuel filter console, and I get fuel. Still won't start.
Spend about 2 hours fooling with it and I finally realize that the 911 feeds fuel in the OTHER side of the MFI filter console. The one I had the pump pressure line hooked to only goes to the check valve and then back to the tank. The MFI injection pump is not in the fuel loop!
I try to hook it up correctly, and the fuel lines are too short.
After a trip to Pep-Boys to buy bulk EFI fuel hose, I am replumbing the filter console when Jason Fox calls. He is having a problem with pulling the motor on his car.
We run over there and I help get the cables off the bottom of the motor. When I get back, it's too late to go back to the car.
So, tomorrow is the day. Hopefully it starts.
