QUOTE(RafalKurda @ Dec 22 2021, 07:27 AM)
Freezin 914
Thank you for your answer, and do you have any information about the engine number? The seller says it is 1975, it is currently mono-injection, but the seller is adding a second engine on carburettors. Do you know any history of this car? Do you have any photos?
Don’t know to much. Car was in Plainwell, MIchigan. Titled in 2014.
Then sold to a friend of mine which just stored the car until I purchased it in 2017. I Sold the car in 2019.
I believe the car to have been painted once. Trunks and engine bay appeared to be Original paint. I purchased the car to do a mild restoration/build. Then fell into a deal on a 911 and then found very clean 914 2.0L car. So I sold a total of 3 914’s in 2 yrs.
The car had a 1.8 with dual carbs on it when purchased. I did not do anything with the car since a purchased it. It was going to be a long term build.
For your privacy, I will not post full vin. But your VIN starts with 474 indicating it is a 74. I do not have the engine number on file but it is indicated on my folder for the car which I made as having a 1.8L. Paint code L96B (Alaska blue metallic) which is posted on the tag inside the drivers door between the door hinges.
Here are 2 pictures of the car as purchased, then the night it was sold.
