PMB Performance DirectFit™ DOT Stainless Brake Line Specifications
Built to the Following Standards
• DOT - FMVSS 106
• SAE - J1401
• ISO - 3996
• GB - 16897-2010
Composition
• PTFE (Teflon®) inner lining
• Braided 304 Stainless Steel Covering
• Clear UV Protective PVC Outer Cover
• Steel fittings: Triple Zinc and Nickel finishes
Features
• High-performance ultra-low expansion rate of 0.000295cc/ft. at 4,000 psi (ZeroFlex™)
• ZeroFlex™ offers extremely precise pedal modulation and feel
• DirectFit™ OE designed fittings and vehicle specific lengths accommodate ease of installation
• Tough UV protective PVC outer coating to protect the braid and resist impact and abrasions
• Protective fitting caps reduce fatigue
• Tested to exceed DOT standards
• All lines pressure tested to 4250 psi
• Ultra-high burst pressure rated to 12,550-13,500 psi
• Extreme temperature resistance -70℃/-94°F to +260℃/500°F
• Compatibility: for all non-petroleum brake fluids DOT3, DOT4, DOT4 LV, DOT5.1
Lifetime Warranty on all Stainless Steel Line Sets
Group Buy Pricing: $99.00 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th***
PMB Performance DirectFit™ DOT Rubber Brake Line Specifications
• DOT - FMVSS 106
• SAE - J1401
• ISO - 3996
• GB - 16897-2010
Unique 5-Layer Composition
• EPDM Inner Layer (excellent resistance to non-petroleum-based fluids))
• Polyester (OET) Inner Braid
• EPDM Middle Interleaf (prevents abrasion)
• PVA Outer Braid (provides strong bonding between layers)
• EPDM Outer Layer for Excellent Ozone and UV Resistance
Features
• High-performance low expansion rate of 0.14cc/ft. at 1,500 psi (LowFlex™)
• LowFlex™ offers extremely precise pedal modulation and feel over other rubber lines
• Tough UV and Ozone protective EPDM outer coating
• Unique 5-Layer Composition
• 10-Year Warranty
• Extreme temperature resistance -50℃/-122°F to +121℃/250°F
10-Year Warranty on all Rubber Line Sets
Group Buy Pricing: $39.95 (914World members only weigh in on this thread, not available for this price online) ***Pricing Good Through January 15th***
