Hey guys...I'm (finally) getting caught up on editing this holiday week. The latest episode of the Bumblebee series is on the rear suspension and brakes. Hope you find it helpful.
Thanks agaiin to the gang at 914rubber @Mikey914 and PMB performance @Eric_Shea for making great stuff to keep these cars going. Links to parts in the description on YT.
This video shows new 100lb springs from 914Rubber and finishes the installation of the trailing arms with their new pivot shafts
Fantastic - break time from a MasterClass to the 914 Master Class!
Mikey914
Dec 28 2021, 01:04 PM
Nice!
Cairo94507
Dec 28 2021, 01:35 PM
Another terrific, informative video that gives all of us amateurs the confidence to work on our own cars. Thanks and Happy New Year Ian.
Eric_Shea
Dec 28 2021, 01:56 PM
914werke
Dec 28 2021, 03:25 PM
No shock bumper? That stepped washer looked to be actually the remains of a bumper where the rubber portion had perished & disappeared
iankarr
Dec 28 2021, 03:59 PM
I thought on these bilsteins the stop is integrated, no?
914Sixer
No shock bumper needed with gas rear. There was no large washer on shock hat, #9 in diagram
Montreal914
Dec 28 2021, 04:26 PM
Thank you for the nice video!
Can't wait to watch it again, when I get to this step!
914werke
Dec 28 2021, 06:40 PM
QUOTE(iankarr @ Dec 28 2021, 01:59 PM)
#6 in Mark's diagram
iankarr
Dec 28 2021, 07:18 PM
Thanks, Rich. i'm aware of the part...just thought that it was integrated into the design of the Bilsteins. There's no mentionn of a stop needed in the installation instructions.
iankarr
Dec 29 2021, 04:16 PM
Anyone have info to add about the bump stop? Curious..
914werke
Dec 29 2021, 04:24 PM
While it may be true that you probably shouldnt ever have an issue switching from oil to gas damped shocks, I still install the Koni replacement bumpers (pictured). I was just pointing out that the stepped washer you reinstalled in the Vid was actually part of, or the remnant from the OE bumper.
iankarr
Dec 29 2021, 09:45 PM
Thanks, Rich. Those bumpers are probably a good idea...cheap insurance. I'm not sure about the origin of that washer. But the entire setup seemed to be original. I don't know why there wasn't a washer under the threaded collar, either. I just maintained the same arrangement. If the brain trust here feels that wasn't a good move, I canl def make adjustments.
914Sixer
Dec 30 2021, 08:59 AM
Factory bump stop similar to this one only orange color. Washer was molded into the base. Rubber disintegrated over time, leaving only washer.
iankarr
Dec 30 2021, 11:11 AM
So...I guess the washer should still be included (even without the stop) since it affects how the hat sits and the length of the rod protruding from the mount.
914Sixer
Dec 31 2021, 07:15 AM
Correct on the washer, you need it even with rubber missing.
Chaznaster
Dec 31 2021, 06:09 PM
Hello all. I am about to start this same job with, coincidentally, the same Biltsteins and springs. What is the recommendation - is the “supplementary spring” (I think that’s what it is called in the Haynes) needed or not? Thanks!
Steve
Jan 2 2022, 08:47 PM
Confusing.. I read only the front Bilstein's have integrated stops. Elephant shows bump stops on there rear bilstein setups. https://www.elephantracing.com/porsche/914/...er-conversions/ https://www.elephantracing.com/911/coilover...ear-bump-stops/ Rear Bump Stop Option – Use existing bump stops or replace them with our progressive bump stops. Curious has anyone used the stoddard rear bump stops? Does the pointed part point down towards the shock? https://www.stoddard.com/91433305301.html.html The picture makes it look like the dome part faces up. The manual shows the dome part pointed down. The stoddard part also looks like a washer goes on the flat fat side. Where can you find the washer?
