QUOTE(mmichalik @ Dec 29 2021, 11:10 AM)
This was the issue I was having. The lights would go up, only one would go down.
Sometimes the one that wouldn't go down would just cycle up and down as well.
It turned out, for me at least, to be a bad relay. But, when I put in the new relays from 914rubber (which are great by the way) it would blow the corresponding fuse.
I ended up finding an old relay that I had, that was still good and, that did the trick (had to go through a few of them)
You can test this out by swapping the two relays you have in there now. The opposite side will not go down. At least that's how I found it out on mine.
Thank you for sharing. I will try some different relays.
