Literati914
Jan 2 2022, 03:06 PM
I’ve seen this talked about before but can’t remember the detail.. I’m looking at an after market wheel that specifies “60 degree” conical lugs. I think Porsche lugs are consider B14, but is that different than 60 degree? I plan on using studs and need to figure out if I’d need to source a special nut.. or would the typical 911 ones work. Thanks.
Van B
Jan 2 2022, 03:19 PM
R14 is the radius/ball seat and it typical of most Porsche cars. Conical are usually 60 degree. I bought some ATS wheels for my car and they will require a conical bolt.
I’m not going to do studs because I hate them, but that’s just me.
914Sixer
Jan 2 2022, 04:03 PM
Ball Seat ONLY for Porsche wheels
914werke
Jan 2 2022, 04:11 PM
No. 60 degree taper is not a 14mm radius ball seat
Literati914
Jan 2 2022, 06:34 PM
Ok thanks, so I’d have to look beyond the Porsche forums for used hardware if using these.. good to know.
Van B
Jan 2 2022, 10:34 PM
I’m going titanium on both my cars. If you’re interested in going baller status too, then here’s the cheapest source:
https://www.acerracing.com/pages/search-res...-page?q=conicalPorsche uses M14 x 1.5mm pitch.
If you go with studs instead of lug bolts, then you’ll need to know what thread is on the stud.
