Hi. This is the first time I am working on my rear suspension, starting with replacing shocks and springs.
I pulled the old shocks/springs just now and there are a few unexpected things I have noted on the right trailing arm...
1) When I lift up on the hub and of the arm, the assembly moves but squeaks and needs some help to get it back down in place. The left one moves up silently and then smoothly returns down without any help.
2) The outer nut and bolt (see pic below) on the arm moves when I push up on the assembly ... but the inner bolt does not. Not sure how that could happen as I understand they are connected.
3) The right unit has 4 shims (see other pic below). There are no shims on the left. Which seems odd.
So ... these things are troubling to me but having never working on these particular bits on a 914, I am looking for some guidance.
Is it time to pull the arm "while I am in there" to dig in deeper? Or just motor on? Note that this is meant to be a fun driver - no plans for AX or racing.
Thanks very much.
