Looking for switches for front and rear fog lamps and the rear heated window. The symbol plates are not so important but would be fine if they are present
914Sixer
Jan 15 2022, 12:07 PM
The part number is 914.614.206.02 for the dual front and rear switch. It was also used in the 74-83 911. Check around for mid 70's VW bus fog light switch with 14mm nut. It can be used for rear window switch.
TheCabinetmaker
Jan 16 2022, 11:12 AM
Don't have a switch, but l do have the pull knob with insert. You can have it for the price of shipping. As said, the fog light switch should be the same
DEC
Jan 17 2022, 12:54 PM
QUOTE(TheCabinetmaker @ Jan 16 2022, 06:12 PM)
Thanks for you offer maybe I come back later for it
914LIVE
Jan 17 2022, 08:18 PM
================================= Good evening.
I have a box of switches. Will check and report back.
Thank you.
