I have a complete SBC conversion package for sale. Everything you need including engine (roller cam 350), tranny (side shift), all conversion parts except the radiator. Here’s the details:
Renegade Hybrids engine crossmember and transaxle mounts, water pump block-off adapters, remote water pump, harmonic balancer, & thermostat housing. Kennedy Engineering clutch, flywheel, pressure plate, and adapter plate. Summit Racing single-wire alternator and high-torque mini starter. Holley blue electric fuel pump wired with a relay and Holley in-line pressure regulator. The engine itself is stock but has been fully resealed; has shorty headers (wrapped), new Ededbrock RPM intake, Edelbrock carburetor, and new HEI distributor.
The engine does currently start and run but the car has been in storage for two years as-is and needs to be timed and tuned with fresh fuel. Previous owner said the motor is fresh, but I don’t have any paper to prove but certainly looks like it.
Conversion parts alone are about $3k on Renegade site, asking $2200 for whole package. Bolt in, add radiator, and go.
