Allan
Jul 30 2005, 12:20 PM
I'm re-installing a stereo that was put in by what looks like a 3 year old. Wires going everywhere and some to nowhere. I need a dedicated 12v power source and another that only energizes when the ignition is on.
Any recommendations?
McMark
Jul 30 2005, 12:27 PM
Hook into fuse 9 for switched power and fuse 11 for constant power. Get piggyback pade connectors and attach them directly to the fuse panel. Don't spice into existing wiring.
Dave_Darling
Jul 30 2005, 01:22 PM
One of the "switched power" fuses usually has a tab with no wires plugged into it. I forget which fuse, but check back there and chances are pretty good you'll find it. That way you only need one "piggyback" connector.
Or, if you've got a stereo that needs quite a bit of power, you could run a new thick wire direct from the battery to the amp/whatever. Make sure to put a fuse in that line within about 18" wire run of the battery!
--DD
Tab914
Jul 30 2005, 03:03 PM
From your signature I am guessing that you have a center consol. For continuous power I ran a wire off of the clock in the consol and it works great for me.
Tab914
Jul 30 2005, 03:05 PM
Forgot to add but if I remember right I am drawing the main power from the thick red and black wire running behind the dash and to the fuse panel. Hope that helps.
McMark
Jul 30 2005, 03:31 PM
I'm not trying to pick on people, but there is absolutely no reason to splice into the main wiring harness with the fuse panel SO close and SO accessible. Sorry, hacking into wiring harnesses has become one of my pet peeves over the years. I've done it in the past, but never again.
Allan
Jul 30 2005, 03:57 PM
Thanks guys. I'm going with Marks suggestion. Whoever installed this one spliced into the harness for the center console. BTW, I don't have a center console yet.
Allan
Aug 12 2005, 03:12 PM
I HAVE TUNES!!!!!!!!!
I think I tapped into fuse #8 though for switched power.
Allan
Aug 12 2005, 03:57 PM
I HAVE NO TUNES...
Fuses look good. I'll deal with it later.
tdgray
Aug 12 2005, 05:04 PM
QUOTE (Headrage @ Aug 12 2005, 05:57 PM) |
I HAVE NO TUNES...
Fuses look good. I'll deal with it later. |
Most modern stereos come with a fuse either on the back of the unit or in an access panel on the back of the unit.
Check that... just trying to help.
