On cylinder number three, with the fuel system pressured up, I get a rapid drip from the auxiliary venturi. The fuel pools on the butterfly below, and (I assume) leaks through the manifold into the cylinder.
So. Before I tear it completely apart - do I order the rebuild kits, or is this a simple adjustment issue?
Other info: The car has 2/3 full fuel tank, and is parked roughly level (maybe a bit high in the rear).
-Rusty
