Does anyone make a replacement channel? Or if it is perforated, can it be repaired using fiberglass mat and POR 15?
Jan 27 2022, 07:23 PM
Restoration Design sells it. Maybe 914rubber.
Jett
Jan 27 2022, 07:37 PM
Just saw the metal on 914Rubber… we need some for a new project
Mark Henry
Jan 27 2022, 07:51 PM
THIS IS THE 914 PO-PO! Step away from the fiberglass sir!
76-914
Just finished my rain channel repair today and used 914rubbers channel. It's spot on and is the correct metric thickness. Each order contains two pieces. One wide and one narrow. Together they form the channel.
bkrantz
Jan 27 2022, 09:58 PM
QUOTE(Geezer914 @ Jan 27 2022, 05:46 PM)
Fiberglass? Don't be THAT guy.
SKL1
Jan 27 2022, 10:06 PM
And after your project Bob, if anyone should know, it's you!
Mikey914
Jan 28 2022, 02:22 AM
Metal is 48" long so you may need more than one set, but it works well. Cary asked us to make these right so we did. Relatively inexpensive and looks OEM. Thay are here
