QUOTE(jmargush @ Jan 29 2022, 06:07 AM)
So more questions after reading Eric's post.
Are there any advantages to using the rear calipers form the '69 912? I assume I would loose the stock E brake function without some work around.
On the front struts will the '69 struts accept the existing koni cartridge that I currently have in my 914 struts?
Th rear 912 brakes would be a slightly better match than the stock 914 brakes but you would need to install the 912 e-brake and use the Tangerine Racing adaptor kit. I would just stick with the stock 914 rear caliper, rebuild it, use good pads and new soft lines.
I don't believe so. I think you have to use koni's built to fit boge struts.
Switching to 5 lug is never cheap. The core parts are only part of the solution. Count on everything needing a rebuild, new pads, rotors, soft lines, bearings, ball joints, etc.
