QUOTE(jim_hoyland @ Apr 5 2022, 03:57 PM)
QUOTE(robkammer @ Apr 5 2022, 06:29 AM)
That took real patience. Or patients, are you an orthodontist? I'm going to take another valve apart today to see if I can adjust it to close completely.
Did you take a temperature reading on the case when it was closed by chance?
Rob
IIRC, they originally didn’t close completely? I had tested and adjusted several on the bench. Timed the closure rate, and tested on my ‘75 L-Jet
In any case, nice work!
they should close completely.
esp the L jet ones.
we have been putting a bit of time into trying to work out what the original factory timing on the L jet ones was. difficult to find out that information. not in any of the literature. repeated searches have got us to a time of approx 8 minutes. i found the info on an obscure/ancient type 4 kombi website. 8 minutes starts at factory spec temp the workshop manual says to test AAV at. which is off the top of my head 50 deg F (but might be wrong, workshop manual has the temp anyway).
as to how much they should be open at cold - another matter.
you can bench test an AAV to see if it basically works. is it open cold and closed shut when warmed. but what is difficult to do is work out how open it should be cold and how fast it should close.
@Van B has gotten real close to solving this one. Van would have to be the most driven member when it comes to having a proper functioning AAV.
he has replaced his with a later BMW one and he can tell you all about it.
D - Jets, thats another matter, but is suspect its similar amount of time.
takes about that long to warm up either engine from a base temp of 50 F.
it looks to me like you kind of can't go wrong with the start opening size with those older D jet ones? from the look of it. its a kind of rotating cylinder? just length of time or whether closing.
design of later L jet ones more of a mystery in terms of having right sized orifice to start with given that nature of the mechanism.
EDIT
oh yeah, this rebuild of the D Jet one by
@brubou is fantastic.
i'm inspired to have a go with an L jet one, but i need a sacrificial patient to botch the surgery on a couple of times to see if its doable.
