QUOTE(robkammer @ Feb 7 2022, 08:09 AM)
My BB is from March of 74 and it's canister was mounted in the engine bay. At some point the canister was tossed, probably when the AC was installed when it was delivered. I've found a canister and bracket and plan to reinstall it at some point. The vent line is mostly intact. As I was getting ready to clean the tank yesterday I found that when they disconnected the vent line they pinched it shut with pliers just outside the filler tube. I plan to drill it out. I've only had about 350 miles of seat time in it and did not notice any starvation issues.
The mounting point is on the passenger side against the front of the trunk by the torsion bars if it was rear mounted.
interesting the vent line was pinched shut.
i'm remembering my old friends euro spec cars better this morning.
his first car was a willow (apple) green 914/4 that came in from germany in the early 70s.
i have no memory of the fuel tank in that one.
the second car he had was a 73 2.0 euro spec converted to rhd by crayfords in england.
it had the expansion tank on top of the fuel tank but no charcoal cannister and plumbing.
i found a photo of it in my files with the front trunk open. the expansion tank was there.
the third car he had was a 70 914/6. that was the car i have remembered had no expansion tank on top of the fuel tank. a euro spec 6 - originally the australian distributor's demonstration car.
the 73 would have vented through the expansion tank to the overflow.
as
@SirAndy remarks must have occasionally smelled of fuel.
though i never remember any complaints. but...if i think about we were all a lot more tolerant of fuel smells back in the 80s.
how the 70 6 vented i have no idea. it could only have done it through the fuel cap?
or maybe there was a little vent valve below the fuel cap where a USA spec car normally plugs in the vent hose that goes to the expansion tank.
i wonder how your fuel tank is breathing?
do you think maybe the fuel cap has been altered or replaced with a breather cap?
maybe having carbs helps?
the EFI cars are definitely relieving pressure and vacuum via the vapor line to the charcoal can which is connected to the atmosphere at the fan housing and the air cleaner.
(with the charcoal in between both atmo vents - the charcoal is the "valve" more or less).
