Geezer914
Feb 7 2022, 04:13 PM
I am installing a Pertronix Digital HP box. Where can I find the 12v ignition switch wire in the engine compartment to hook up to the distributor? Anything on the relay board? Thanks. I am great with mechanical stuff, but electrical is like opening a can of worms.
JeffBowlsby
Feb 7 2022, 05:30 PM
The AAR wire (white) on the ignition harness is switched 12V.
Geezer914
Feb 7 2022, 06:17 PM
AAR? Aux air regulator? The only problem is I have 1.8 Let not 2.0 Djet.
sportlicherFahrer
Feb 7 2022, 07:22 PM
On your original ignition harness that lays across the engine from the relay board to the coil, you have two wires going to the coil. Black, and black with a stripe. Black was your original coil +12V supply that is switched, and the other with the stripe is the tach signal.
Geezer914
Feb 7 2022, 09:40 PM
Already have 2 wires coming out of the box going to the coil.
sportlicherFahrer
Feb 7 2022, 10:08 PM
QUOTE(Geezer914 @ Feb 7 2022, 07:40 PM)
Edited my last post for clarification.
Geezer914
Feb 8 2022, 02:49 AM
Got it! Next question, is the tach a voltage spike tach?
sportlicherFahrer
Feb 8 2022, 07:48 AM
Original tach uses a pulse signal. You will likely need a conversion unit to take what I bet is a square wave from the box and turn it into a pulse to get the tach to work. I have MSD on my car and used their tach adapter with no issues. Not sure what part number at the moment.
Alternatively, the tach could be rebuilt with a newer drive unit that uses a square wave.
Geezer914
Feb 23 2022, 10:39 AM
Still sorting this out. I have a 75 914 with Ljet fuel injection. Where can I connect the red wire coming from the distributor and the box to the ignition switch?
MartyYeoman
Feb 23 2022, 11:48 AM
Hope this helps. It's what I used on my '75 L-Jet. All works fine.
Geezer914
Feb 23 2022, 12:01 PM
I separated the black wire from the black/red wire left the black/red wire on the + side of the coil and connected the black wire to the red wire. The wires coming off the positive side of my battery are fused. I hit the start switch and blew a fuse. ?????
