Thinking about selling my 1976 2.0.
Your $12k budget is a little lower than my target, but I'm open for negotiation.
Want it to go to a good home
2nd owner. Owned it for almost 20 years. Always garaged. Was originally bought in St. Louis by a dentist, and I brought it to the Kansas City area.
Odometer shows 82k, but it is really in the 75k range. Original owner had a cluster failure and replaced the odometer. I have a picture of the 2 odometers next to each other.
I also have the logbook from the original owner showing all maintenance.
All original except the fuel lines have been replaced with stainless steel.
Hasn't been on the road since 2015, but has been consistently titled.
Was running in 2015, but was having a fuel pressure issue that I haven't found the time to work through.
Started up and pulled it out of the garage for the pics (no problem other than having to jump it).
Paint is original (I believe), and is ok (not great). Previous owner tried to touch up a bunch of spots on the drivers door, but did a poor job. Also looks like somebody leaned against the right rear fender and flexed it enough to crack the paint there. A little surface dusting of rust at that location, but no penetration into the metal.
Original battery tray has some rust, but the hell-hole is solid.
Interior is great with no cracking other than a 1" cut in the driver's door and a cracked passenger side visor mirror.
Let me know if you are interested.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
