I managed to locate (2) early 911 wiper switches available for the steering column conversion. $250 each
I also found (1) turn signal headlight switch this is the left side of the column. It needs there new plastic end put on $ 200.
These are the switches needed with the 911 early column that allows a 911 ignition and steering wheel lock.
Jim Dorociak jdorociak@gmail.comClick to view attachment
