QUOTE(Root_Werks @ Feb 11 2022, 07:32 AM)
QUOTE(mlindner @ Feb 11 2022, 03:11 AM)
Worn, is this your 4 or Six. On my 6 conversion, I wanted a better jack point so I put a bar across from the old engine support to the donut. With the extra weight of the six it works well and spreads the weight out. Best, Mark
I was going to remove the 4cyl mounting steel on my six conversion, but after looking closer at it, left it there. Going to put some sort of metal/rubber puck on each 4cyl mount. Makes a great jack point.
Thanks Mark.
That ship has sailed. The six has the mounts removed. That car is all rewelded and solid and a dream to drive. Not quite as pretty as yours.
No, I have been welding the four cylinder car. I rebuilt the motor, didn’t take enough care about oil leaks, took the motor back out to reseal and while I am at it wouldn’t it be nice if the car didn’t fold in half. Actually, like many cars of that era it was a well designed monocoque with extra strength. Dimensions were fine despite the hell holes.
I was thinking that often the thing you have the jack on is the same as the thing you want to put the jack stand on. Maybe a bit of something along the pinch weld?
