TonyA
Feb 11 2022, 07:06 AM
Trying to start an engine without installing the gas tank yet. If I put a small one gallon gas can in the tank compartment will the pump pull the gas up and out to fire the engine. I am trying to do this and not getting any fuel to the engine. Does it need to be gravity fed out the bottom of the gas can.
Highland
Feb 11 2022, 07:54 AM
As long as the pump is lower than the pickup in the tank it should work. Is this stock F.I.?
TonyA
Feb 11 2022, 08:06 AM
QUOTE(Highland @ Feb 11 2022, 08:54 AM)
Yes stock FI I even switched out the three port pump. Still no fuel to engine. Question if I wired the pump wrong would it run backwards and not work?
VaccaRabite
Feb 11 2022, 08:19 AM
if its wired wrong the pump will not run or will run backwards.
The pump needs to be lower then the tank or fuel won't get to it - the pumps are not good a sucking air.
If you have a pressure regulator and it is plumbed backwards the pump could be right but gas still won't get to the engine.
Zach
TonyA
Feb 11 2022, 10:05 AM
QUOTE(VaccaRabite @ Feb 11 2022, 09:19 AM)
Zach
Thanks sounds like I just need to put the tank in anyway and check the wiring again
ndfrigi
Feb 11 2022, 10:30 AM
and maybe you can get a loaner fuel pressure kit to test.
930cabman
Feb 12 2022, 06:53 AM
Is this the first start of a newly rebuilt engine?
TonyA
Feb 13 2022, 07:08 AM
QUOTE(930cabman @ Feb 12 2022, 07:53 AM)
No swapping a engine in that sat for about 8 months. It fires when I put some gas in the throttle body then stops. Not getting fuel. I’ll reluctantly put the tank back in and try next week.
Spoke
Feb 13 2022, 09:14 AM
If you route the fuel hoses to loop from the right side of the car to the left then back to the tank, you can connect the tank w/o installing it. Also makes it easy to pull the tank for any reason. If done carefully, the hoses will not kink.
TonyA
Feb 14 2022, 07:24 PM
Good idea i think I will try that! thanks,
