QUOTE(ndfrigi @ Feb 11 2022, 06:51 PM)
how about use direct 12 volts to fuel pump if it will run the pump. And maybe just go with the 2 port (late type) fuel pump for less return fuel hose.
as windforfun says - what do you mean by relatively recent?
a reconditioned one or a second hand one?
if second hand the motor has probably given out.
powering it up direct from a battery will tell you.
i rebuilt two of these myself earlier last year.
both of them were only worth doing because the brushes and commutators were barely worn. i rebuilt them with new seals all the way through to stop them leaking.
but did not do anything else to them.
most of them are going to be so worn out they will jam at the armature either when the brushes fail or a chunk of armature comes off. the failure will be immediate and catastrophic.
ps, if you have a L jet the pump won't run anyway until you crank.
unlike the d jet cars.
even with fuel pump relocated that wiring circuit is probably still intact that means it only runs on cranking.
