QUOTE(Purple Frog @ Feb 14 2022, 10:16 AM)
I'm thinking the original design never intended to spin the alternator that fast.
Any solutions out there?
You are correct that OE design was never intended to support those sort of RPM's.
When accessory drive systems start throwing belts (V-belts, sperpentine, whatever) you're going to find two likely causes.
1) Static Pulley misalignments that put side loads on the belt, making it inclined to jump.
2) Dynamic pulley alignment issues. The system is going into resonance at some critical speed. When the system goes into resonance, it is shaking in on (or more) of the X, Y, or Z planes. The only solution to resonace is to move the resonant frequency. Doing this is not as easy as it looks and usually requires a few accelerometers to be placed on the components to understand the frequency of the resonance and its modes (what motions are occuring).
The 914 alternator brackes are a terrible design but work well under the stock operating parameters (i.e. only short excursions to about 5500 rpm).
Click to view attachment The U-bracket that attaches to the fan shroud is very weak and is going to be inclined to resonate fore/aft. As it does so, the pulley alignment will be affected.
The alternator adjustment braket is even worse and provides very little if any additional fore/aft support. It is long, thin, and operating in single shear.
Bottom line, it's archaic . . . but works in stock configuration.
If I were trying to improve it, I would likely move toward some sort of billet U channel arrangment that would have far more fore/aft stiffness than this little steel U-bracket.
As noted by others try, the proper belt size, and make sure your pulleys are properly aligned (statically). After that, you're going to be looking at design modifications to improve dynamic robustness.
