LS swapped Porsche 914 paired to a Boxster S 6 speed manual transmission. Engine is the 5.3L LM4 all aluminum block and heads and uses an upgraded stage 4 cam from summit racing as well as upgraded fuel injectors from Holley. Had about 120k miles when I bought it and passed pressure testing. Transmission was purchased with about 80k miles on it. Uses drive-by-wire throttle utilizing the original 914 throttle pedal. ECU is the Holley Terminator X max. Upgraded suspension with new bushings and ground control systems coil-overs in the rear with Koni shocks both front and rear. Has heat, AC, and a hidden Bluetooth DSP. Car had about 86,xxx original miles and was stored in a garage in 1991 until I got my hands on it and brought it back to life March 2021. Still have the original hood and the incomplete original 1.7L engine, both of which will be sold with the car if wanted at no extra cost. Car runs and drives perfectly. Have driven to San Diego and back many times last summer with no issues. I use the vented hood shown in the photos when driving since the wheelwells are not cut. Original hood is provided in case new owner prefers cutting the wheelwells.
Tags good until January 2023. Brand new starter, brake pads, belts, and bushings throughout. Title on hand.
Known flaws: small rusted through hole in the passenger side fender. Some rusted through areas underneath the trunk carpet. Various paint chips. Areas painted black either had minor surface rust or just exposed steel.
Link to post: https://www.facebook.com/marketplace/item/488123816283429
Link to photos: https://drive.google.com/drive/folders/1Fhg...mKz?usp=sharing
Asking $29,000 cash obo
Edited to add more description on the engine and transmission.
