partwerks
Feb 14 2022, 07:09 PM
Can the turn signal switch part be removed from the wiper switch part?
I'm guessing that it just slides up on the four pins, but I don't want to just get rammy on it. Thought I should ask first.
windforfun
Feb 14 2022, 07:18 PM
Yes. They're independent.
partwerks
Feb 15 2022, 08:44 PM
After removing it, one of the copper contacts has about an 1/8" hole rubbed through it on the high point. Is it still going to be usable?
windforfun
Feb 16 2022, 10:40 AM
It's hard to say. It sounds like it's shot. Just remember not to tighten the four screws when you reassemble things. Those mechanisms need to "float" to work right. BTDT.
cholland_
Feb 16 2022, 12:18 PM
If it's shot, I replaced the switch on my '73 with this cheap Beetle part:
https://www.cip1.ca/vwc-111-953-513-f/It was a direct fit.
