QUOTE(bdstone914 @ Feb 19 2022, 10:34 PM)
QUOTE(Medtner3 @ Feb 19 2022, 06:00 PM)
I need to replace the clear brake lines in the front of my 914... could someone possibly tell me the size of the cloth lines under the master cylinder reservoir and the size and length of the clear tubing from under the reservoir?
Can I assume any of the correct size clear plastic tubing would work and could maybe get at the hardware store?
Just asking because if that is the case I could fix that this weekend and put my rebuild back on track rather than waiting on parts to ship to me
@Medtner3 I think they are 8mm ID. If you use a locally available source make sure it is intended for petroleum use. Most clear hose you find in hardware stores is meant for use with water.
Why? Brake fluid is not petroleum based, and most rubbers (with the exception of silicone) that are approved for petroleum oils don’t play nice with brake fluid.
OP…when the blue brake fluid hose was tough to get for a bit back in the late ‘90s (at least for me)…we used to use the 5/16” clear braided “dishwasher hose” you can get at Home Depot….worked well and brake fluid didn’t react with it.
