This is an original 16mm rear sway bar that was powder coated. New brackets and rubber bushing are included. The drop links were powder coated. They will be supplied with new Porsche brand bushings. I installed Uro parts bushing and they distorted and tore during installation.
The shock bolts are original Porsche with new lock washers and replated flat washers.
If your car did not originally have rear sway bar you will need to weld in the correct sway bar bushing plates to the bottom of the trunk. You can also drill holes in the trunk and use support plates on the top side of the trunk.
$400 plus shipping.
