QUOTE(GregAmy @ Feb 21 2022, 08:24 PM)
Yup
"Relocates the clutch pulley to a horizontal position for better ground clearance and improved cable routing to clear exhaust header systems. Two sets of mounting holes allow adjustment for clutch cables that are too long, a common problem."
http://www.tangerineracing.com/transmission.htmThe reason the clutch cables are "
too long" is because they were built to factory specifications. The specification was for the original plastic clutch clevis.
Click to view attachmentSomewhere along the line, the original clutch clevis was superceded by the one we have now.
Click to view attachmentIt is much shorter and does not have rounded pins on the side like the factory one.
If you want to go more authentic and eliminate the spacers everyone puts on the cable, then get the clutch clevis from a 70-71 911. It will fit the cable and is the correct length. Weltmeister makes a great aluminum aftermarket one.
Click to view attachmentClay
