@trojanhorsepower I had an issue with Tangerine Racing tubes as well. The issue was the bend at the gas tank was not enough to allow room for the hoses to connect. I had to further bend them to allow room for the hose connections.
Here's the initial install. The pipes point right to the front wall.
Click to view attachment So I further bent the tubes to give more clearance.
Click to view attachment Now they fit better and I could easily get the hoses over the tubes. It doesn't look much different in the pictures but the fit was much better.
Click to view attachment I opted to not connect the lines directly to the gas tank as I didn't like being under the car making connections and especially if the tank needed to be lifted for any reason then trying to disconnect the tank. I even welded closed the round access hole.
The hoses are routed to the driver side where I mounted the fuel pump.
Click to view attachment The hoses do not kink and the extra hoses allowed me to do all the connections above the car and if the tank needs to be pulled, just lift the tank. I can still run the engine with the tank lifted. Also allowed me to check for leaks once all the hoses were connected.
Click to view attachment [u][/u]
