Rebuilt 3.2 engine. Includes DME and harness. $28,495
Email- Mark@MarkEpstein.net to purchase.
It runs very strong in the car. I will upload a video of it running.
Full tear down and rebuild
Crank polished
Rods reconditioned
ARP rod bolts
New main bearings
Clevite ceramic coated rod bearings
New intermediate shaft bearings
Reconditioned oil pump
New iswis timing chains
All new timing chain ramps
New canyon headstuds
Pistons & Cylinders inspected and new rings.
Cylinder heads have new valve job and surfaced. Guide checked and replaced as needed
All new seals and gaskets
Rebuilt injectors
Fuel injection was completely disassembled and parts replaced as needed
New cylinder head temp sensor
Stock heat exchangers thoroughly cleaned
Stock muffler modified with two out in the center.
All engine components were ultrasonically cleaned.
Oil cooler was pressure tested
Engine was installed in car, run to break in cams and then tuned ~10-20 miles
Available for pickup or ship.
