Hi:
Yes, there are a lot of threads on this and I just read most of them. Including ones with detailed charts of how to tell different HE's apart. I probably missed it but there seemed to be no distinction between 1.7 and 1.8. I.E., if the rear of the pipes curve up they will work with either engine.
My 1.7 came with no HE shrouds on the pipes so I located a used set and pulled the old pipes off this weekend. To my surprise, they are larger in diameter than the 1.7 set I purchased. The "new" set is 36mm - which agrees with the research. However, my "old" set is around 42mm, thanks to a transition at the engine end. See photo. Otherwise, in terms of length and layout they are identical.
I'm certain my engine is the original 1.7 that came with the car so I have no idea where the larger pipes came from. Can anyone help me figure this out?
Thanks,
Ron
