QUOTE(GregAmy @ Mar 1 2022, 01:41 PM)
Are you looking for a "short shift kit" or are you looking to clean up your sloppy shifting?
IMO, no value in the former, and this takes care of the latter:
Tangerine Racing Shift Linkage Kit, plus
Shift Rod Bearing
http://www.tangerineracing.com/transmission.htm I installed a similar unit to the rennline in a 914 around 40 years ago. It only improves the fore and aft, not the side to side. It will not fix a sloppy shifter, seals, ect.
A little bit of a pain to heat up the base to remove the old shifter and then glue the shifter to the new base. I recently bought a Weltmeister short shifter for one of my cars, which came with the whole shifter and base. This is an easier swap if you can find one. Do a WTB in the classifieds, someone might already have one installed.
