a.munoz3
Aug 1 2005, 12:18 AM
well............ ive had my 914 quite a while but havent had much time to mess around with but never hardly tooken it on the freeway. I decided why not hmm take it on the freeway and about 60 mph my steering wheel shakes and it shakes less if i speed up
?? confusing do i need to have a balance job done?
Jeroen
Aug 1 2005, 04:34 AM
most likely, your wheels/tires need to be balanced
also check for play on the wheel bearings and balljoint
ArtechnikA
Aug 1 2005, 06:12 AM
and tie rods...
KevinP
Aug 1 2005, 07:38 AM
Think I would check the brake rotors too....
Aaron Cox
Aug 1 2005, 08:36 AM
check wheel balance...and get your car aligned.......
Joe Bob
Aug 1 2005, 08:58 AM
Could be flat spotted tires as well.
tdgray
Aug 1 2005, 09:09 AM
QUOTE (a.munoz3 @ Aug 1 2005, 02:18 AM) |
but never hardly tooken it on the freeway |
Have them check your grammer along with everything mentioned above
Sorry just giving you
TonyAKAVW
Aug 1 2005, 09:18 AM
I had the same problem. Just got new tires mounted and balanced the other day and the problem is completely gone.
-Tony
lapuwali
Aug 1 2005, 10:47 AM
Try swapping your front tires to the back and see if the problem changes. If it's wheel balance or an out-of-round tire, there will still be vibration, but you'll feel it through your butt instead of through the steering wheel. If it doesn't change, it's a wheel bearing or a balljoint, most likely.
a.munoz3
Aug 1 2005, 01:19 PM
thx for the help
RustyWa
Aug 1 2005, 01:30 PM
When you get your wheels spin balanced, will the machine notice if your tire has a problem like a flat spot or a problem with a rim?
lapuwali
Aug 1 2005, 01:47 PM
QUOTE (RustyWa @ Aug 1 2005, 11:30 AM) |
When you get your wheels spin balanced, well the machine notice if your tire has a problem like a flat spot or a problem with a rim? |
The tech should notice. You can see it wobble on the machine, and it will be hard to impossible to balance.
