QUOTE(Blue2Shado @ Mar 2 2022, 07:51 AM)
So I've got a 73 914 and am having the engine checked . So far the news is all good.
My question is will the stock FI work with 96mm pistons, larger throttle body and a little more aggressive cam?
"Can be made to work" is a better way to say it.
D-jet systems are designed to run on the exact configuration of motor they were sold on, any deviations from the stock motor config and you basically have to hack the d-jet system to get it to function decently
and
"Decently" != "Ideal"
It can be made to work, within limits, but you will always be leaving something on the table vs say a fully programable FI system.
On a modified engine a larger throttle body can be of benefit but if you are sticking with d-jet I probably wouldn't bother as d-jet is going to be more of a limiting factor in a performance build than your throttle body anyways.
My basic rule at this point is that d-jet is for stock motors. If you want to build anything beyond stock its more than worth it for many reasons to ditch d-jet. Even on stock motors these days an argument could be made to ditch it, but that is opening a whole other can of worms.
