Asking the engine builders here:
Is it ever an option to reuse rod nuts /4, stock crank, rods, mild cam, 96mm pistons, carbs, street use only by adding maybe 5 ft/lbs to the rod nuts? They were torqued once to 24 ft/lbs and wishing to reuse them could I get away with maybe 30 ft/lbs?
thanks
