Got the fuel pump to pump. But still won't start up. I have fuel up to the input of the fuel regulator. The hose is still attached in the pic. I started to take off that hose and right away fuel was dripping.
The other side that you see the hose is offhad ZERO fuel coming out. I put a little bag under the outlet end of the regulator and turned the ignition on for the pump to activate and nothing coming out this end that attached to the fuel rails on the driver's side.
Am I to assume that I need a new fuel regulator? Or can the fuel regulator be fixed?
And does the fuel first go in the regulator and out on the drivers side of the engine and then flow over to the passenger side and then once the injectors detect that, they are supposed to fire up?
Absolutely a newbie on all this. 1973 914
Any help is greatly appreciated
